2000 Ford Windstar air blows but no heat
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
BUD MULLEN
air blows ok, but no heat. A few days ago it started a rythmic "click: pause "clackrepeat, sound from under the dash. Then it stopped and now no heat.
Dec 10, 2008 at 5:55 AM
JAMES W.
  • 2,394 POSTS
Do you hav e auto temp control, or just a warm/cold adjustment? Please advise.
Dec 20, 2016 at 10:08 AM
BUD MULLEN
it has a manual lever cold to warm control
JAMES W.
  • 2,394 POSTS
I'm trying to imagine what the "click/clack" would be. As near as I can figure, that was your blend door cycling due to a bad temp control vacuum switch or vacuum actuator. The noise was the door moving back and forth from heat to cool and finally failed and I believe the default position (with no vacuum) is cool. Check to see if you have vacuum at the blend door actuator with selector switch in the floor heat position and temp control in "hot". If no, move the blend by hand to see if you get heat. If you get heat, the actuator is bad. If no vacuum in heat or cool position, the temp selector control is bad. Hope this helps.
