2000 Ford Windstar
187,000 MILES • 6 CYL • FWD • AUTOMATIC
BOWMIESTER
What can cause engine miss fire? Already installed new wires and plugs.
Mar 13, 2010 at 3:48 PM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following-Inspect ans test all the following listed below:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
Mar 13, 2010 at 4:04 PM
