2000 Ford Windstar
CRAZYHORSE007S
Electrical problem
2000 Ford Windstar 6 cyl Front Wheel Drive Automatic
on a 2000 windstar w/33.8l
The computer won't communicate with the code reader because there isn't any power at the port.
How can i fix this issue?
Aug 18, 2010 at 10:35 AM
WRENCHTECH
  • 20,760 POSTS
Check fuse #17 (20amp) in the under dash fuse box. It also powers the cigarette lighter.
Aug 18, 2010 at 11:54 AM
SATURNTECH9
  • 30,869 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_2000_windstart_obd2_part1_1.jpg
I want you to take a multimeter and test pins 4 and 5 on the obd2 connector for ground make sure they read 2 ohm's or less to ground.Pin 16 should have battery voltage.If pin 16 doesn't have battery voltage then check fuse number 17 in the battery junction box.
Aug 18, 2010 at 11:57 AM
