1999 Ford Windstar vehicle will not come out of park when e
127,000 MILES • 6 CYL • 2WD • AUTOMATIC
GREYGHOST09
all of a sudden I put the key in and it will not come ourt of park when the vehicle is on or running. I can put the key to unlock position and put the van in neutral and start and drive, my barake lights don't work either.d is this all connected to a swith that disengages with the brakes or what?
Apr 26, 2010 at 8:52 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like the brake light switch has gone bad.The switch controls the shift lock as well as the brake lights
Apr 26, 2010 at 3:14 PM
GREYGHOST09
Where is that switch located? Is it in the engine compartment? down by the shifter linckage?
Apr 26, 2010 at 4:18 PM
GREYGHOST09
The messagein respose to my last question was in some language that I couldn't read. could you re send it in english.
Apr 27, 2010 at 7:31 AM
2CARPRO JACK
  • 11,533 POSTS
The brake light switch is under the dash mounted on the brake pedal assembly
Apr 27, 2010 at 9:30 AM
GREYGHOST09
thanks
Apr 27, 2010 at 10:15 AM
2CARPRO JACK
  • 11,533 POSTS
My pleasure, thanks for using 2Carpros.com
Apr 27, 2010 at 11:51 AM
