Suspension problem
1999 Ford Windstar 6 cyl Two Wheel Drive
My '99 windstar subframe has separated from the side rail/frame where the bolt and bushings are. the subframe has actually rusted through and split allowing the subframe to come off of the bolt and bushing. Is there a way to fix this or does the entire subframe need to be replaced?
Feb 23, 2009 at 4:13 PM
