1999 Ford Windstar Starting problems
134,000 MILES • 6 CYL • 2WD • AUTOMATIC
JCMCNEELY
Drove to store and when I came out the engine started and ran for a few seconds and then would not start. After about 5 minutes engine started and ran fine for about 9 months and then did same thing yesterday. Waited about 15 minutes and engine started and ran fine for a day. Drove to store and when I came back out the Van would not start.
Mar 24, 2010 at 5:56 PM
  • 75,988 POSTS
Did you have a check engine light come on or has flashed prior to this problem and when was your last tune-up?
Do below to determine whether it's fuel or spark issue:
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Mar 24, 2010 at 6:45 PM
