1999 Ford Windstar o/d light blinking
132,000 MILES • 6 CYL • FWD • AUTOMATIC
KIDSPLAYMUSIC
The od light blinks on and off.. what does that mean.. the transmission does not shift from 1st to second right away. It does work well then there is no problem. It seems to run fine. But just want to make sure.
Sep 4, 2010 at 8:15 AM
BIGTOM1503
[quote:1ab5bcdad3="kidsplaymusic"]Transmission problem
1999 Ford Windstar 6 cyl Front Wheel Drive Automatic 132000 miles
The od light blinks on and off.. what does that mean.. the transmission does not shift from 1st to second right away. It does work well then there is no problem. It seems to run fine. But just want to make sure.[/quote:1ab5bcdad3]
Sep 7, 2010 at 3:07 AM
KISSAWIND
I hate to give bad news, but our 2001 did the same thing and we had to have the transmission rebuilt. There is a sensor on the trans that you can try to replace first for around $35.00, but it did not fix our problem.
Sep 7, 2010 at 4:39 AM
