Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Windstar
Climate Control
Air Conditioner
Not Working
1999 Ford Windstar Not Cooling
1999 FORD WINDSTAR
98,000 MILES • 6 CYL • 2WD • AUTOMATIC
EMANEN
MEMBER
1 POST
The air conditioner will blow air but not cool air. What can I do that will not require me taking it to a service center?
Jul 19, 2008 at 8:15 AM
BMRFIXIT
Experienced Mechanic
check when ac on -ac comp clutch on- also
check fuses
check the ac lines under the hood
low side should be cool
check system pressure if low add some
if line cool
check blend door motor behind the clove box
Jul 20, 2008 at 1:23 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
