1999 Ford Windstar noisy steering
IKIMAUD
  • 1999 FORD WINDSTAR
  • 6 CYL
  • FWD
  • 130,000 MILES
Hi. When I turn the vehicle it gives a whinning noise. The fluid is grey/black.I had the steering rack and pinion fully replaced 6 months ago because of a bad leak from the rack. What could the problem be now?
Monday, January 12th, 2009 AT 12:11 AM
  • 110,182 POSTS
Hi:
First, the fluid should be clear so you may want to have the pump serviced. Also, this is a common problem with the powersteering pumps on this vehicle. The pump itself may be going bad. The only problem, if you replace it with a remanufactured one from a parts store, they too seem noisy. The only suggestion I have is to try the service. If it doesn't help and the sound is too bad to tolerate, try replacing the pump, but I do recommend getting a new factory pump or a warranty saying an aftermarket will not make a similar noise.
Tuesday, January 13th, 2009 AT 3:23 PM
