1999 Ford Windstar knocking noise
JUAN J GARCIA
Heater problem
1999 Ford Windstar 6 cyl Wheel Drive Type unknown Automatic 110,00 miles
try turning on the heater only cold air coming out and a knocking noise ??? need help thanks juan
Apr 1, 2008 at 4:14 AM
PAPIO4906
Had the same problem. Heater in the back worked fine, but the front was stuck in the cold position. I could get the knocking noise to stop if I moved the front temp adjust slider **** about 1/2 inch from cold. Finally took it in after one too many cold winters and they replaced some motor for $200. Works great again.
Nov 30, 2010 at 3:43 PM
