1999 Ford Windstar KNOCK SENSOR
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHEWEE
MY VAN RUNS HORRIBLE ALL OF A SUDDEN JUST REPLACED THE ENGINE 4 MONTHS AGO. SINCE PROBLEM CHANGED PLUGS AND WIRES, AIR FILTER, AND FUEL FILTER. CHECKED COIL PACK. IS THERE A KNOCK SENSOR ON THIS MOTOR BECAUSE ITS GIVING ME A TAPPING NOISE AND IT SPITS AND SPUTTERS/
May 20, 2008 at 7:15 AM
MASTER TECH DAN
  • 83 POSTS
is there any check engine lite are you sure the wires are in the correct oder also did you reset the syncro for the dist in the correct spot there is a special tool
May 20, 2008 at 7:29 AM
CHEWEE
MECHANIC PUT PLUGS ON AND HES NO MASTER MECHANIC. WORKS IN A SHED DO NOT KNOW IF HE HAS SPECIAL TOOL.
May 20, 2008 at 7:50 AM
