1999 Ford Windstar intermittent starting
100,000 MILES • 6 CYL • FWD • AUTOMATIC
RLBATEZ
The vehicle sometimes makes a clicking noise instead of starting. after a few trys it usually starts and runs fine. usually acts up when cold out, battery is new and connecton at the battery is clean.
Jan 26, 2008 at 2:45 PM
MIKE H R
  • 3,094 POSTS
check the connections going to the starter make sure they are clean and tight. If you are getting voltage to the starter there is a good possibility the start is getting weak or going bad. Best thing is have it checked out.
Jan 27, 2008 at 2:53 AM
