1999 Ford Windstar ignition
214,321 MILES • 6 CYL • FWD • AUTOMATIC
KEAGANKAYLIN
I have a 1999 ford windstar and it worked fine until the other day i drove home from work and i got out the van and went in the house.When i came back out to start the van to leave again it wouldn't start.The dash lights come on and everything works inside,and i checked to see if there is power going to the starter and there is.But it is dead on the key,and there is also no power going to the fuel pump.
Any ideas??????
jim
Mar 23, 2008 at 5:56 AM
MASTER TECH DAN
  • 83 POSTS
the electicial part of the ign switch could be bad also do you have power at the purple wire at the starte any aftermarket alarm installed the module could be bad
Mar 25, 2008 at 12:59 PM
