1999 Ford Windstar hellp
1999 FORD WINDSTAR
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
RVEGA
I replace the ignition cilinder on my windstar and after that it won't star. It have power on all the fusses and relays but wen I turn the key on the fuel pum cut off earlier than it should and the starter don't even click. I have changed the starter and fuel pump relays but it does nothing. I have even check the ignition switch. please tell me what to do.
thank-you
Jan 4, 2008 at 11:37 AM
MERLIN2021
  • 17,250 POSTS
Check battery voltage! how long was the door open? if the volts go below 9, PCM will not work! Try a jump start...is anti theft light flashing?
Jan 4, 2008 at 12:03 PM
