1999 Ford Windstar Heater Control Valve
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
DROOPYRW
Where can I find the heater control valve on a 1999 Ford Winstar? How hard is it to change?
Mar 25, 2008 at 7:11 AM
MASTER TECH DAN
  • 83 POSTS
you probly have a broken vaccum under the hood near the heater core it is a red line very common
Mar 25, 2008 at 12:40 PM
BOBDUCKETT
The most common problem to cause loss of heat or A/C in Ford Windstars is broken blend doors. The blend doors are located inside the plenum box, which sits underneath the dash near the glovebox. In order to access/replace the blend doors, the dash must be disassembled and the plenum box extracted. There is also some methodology popping up online that allows you to access the blend doors by removing the glovebox and making a cut in the plenum box, it is much less labor and time. Here is more info about the problem.
Nov 19, 2010 at 10:19 PM
