1999 Ford Windstar front heater not giving heat
WERGROSS
  • 1999 FORD WINDSTAR
  • 6 CYL
  • 20,000 MILES
Our van has dual heater contols 1 in the front and 1 for the back. Our heater is not giving heat in the front but it is in the back. Can you tell us what the possible trouble can be?
Monday, October 6th, 2008 AT 8:07 PM
GEARHEADWHIT
  • 5 POSTS
Probably air blend door actuator is stripped. Does it make a noise when you move the temp control from hot/cold?
It's easy to access. Remove lower console, 4 plastic screws, slide out of the way. Lie on your back and look up behind the stereo, should be a white plastic box with an elect conn.
Saturday, October 11th, 2008 AT 4:42 PM
