1999 Ford Windstar Check Engine light stays on
55,000 MILES • 6 CYL • FWD • AUTOMATIC
ENRICOMAD
  • 6 POSTS
I have a 1999 Ford Windstar and the Check Engine light and brake light stays on. I do not know the cause. The car runs fine However I cannot pass NYS inspection with these lights on. In the past we've had to reset the system in order to get these lights to turn off. Then I had to put on about 70+ miles before the diagnostic computer would allow an inspection to complete and pass.
These lights would stay off for a few weeks and then come back on again.
I need to know what the root cause is for this problem.
Obviously a sesnor in the engine is telling us that something is not quite right. It does not seem to be affecting the performance of my car but it is creating a frustratin situation when I attempt to pass inspection.
Please email me at enricomad@yahoo.com
Thanks,
Enrico
Jul 6, 2009 at 3:25 AM
2CARPRO JACK
  • 11,533 POSTS
You will need to have the PCM scanned for trouble codes.Possibly may need to scan the ABS system to see if has any codes pertaining to the brake light being on (as long as brake fluid is full)
Jul 6, 2009 at 10:43 AM
ENRICOMAD
  • 6 POSTS
Are you referring to the PowerTrain Control Module?
I believe my mechanic has run diagnostic tests already but with no solid results. I will ask him to do this, but do you have any concrete solution?
What is your best educated guess as to the cause of this problem?
Thanks,
Enrico
Jul 7, 2009 at 4:59 AM
2CARPRO JACK
  • 11,533 POSTS
No guesses. there are at least a dozen things that can do this.If he has a scanner , he should be able to get codes out of it, if not find a shop that does
Jul 7, 2009 at 6:00 AM
ENRICOMAD
  • 6 POSTS
OK. I will have the computer scan done tomorrow.
Thanks. Will let you know what we find.
Jul 7, 2009 at 12:10 PM
ENRICOMAD
  • 6 POSTS
The PCM was scanne dthis morning and it gave a manufacturere's code 'P1518- Intake Manifold Runner Control (IMRC) Stuck Open'.
He is in the process of replacing the part.
Any insights here? Will this solve the problem?
Jul 8, 2009 at 2:55 AM
THEMARCIAN
  • 29 POSTS
I just had same problem. Someone took apart my intake manifold and cleaned it out with a cleaner and my light has been off since.
Aug 30, 2009 at 11:19 AM
ENRICOMAD
  • 6 POSTS
After the Intake Manifold Runner Control (IMRC) was replaced the check engine light remained off for 500 miles, when it suddenly appeared again.
Any more insights you can send my way guys?
Enrico
Sep 8, 2009 at 8:29 AM
SCHRIMPIEMAN
  • 166 POSTS
The IMRC valves often fail in pairs. Despite how expensive they are, you'll be best off replacing both IMRC's if the following test FAILS:
Theory: The IMRC valves work off of engine vacuum, both being operated off the same 'trunk' vacuum tube. The vacuum line simply splits to left and right banks shortly before being attached to the actual IMRC acuators. Thus, if one of the IMRC valves has a leak, it will affect the operation of the other (even if there's nothing wrong with the other).
Try this easy test: Disconnect the vacuum tube from each of the two IMRC valves. With engine OFF (no vacuum needed for test) turn the IMRC. You will feel rotational spring tension where the IMRC wants to rebound to its original position. Place your finger over the port where the vacuum line was attached. Remove your hold on the rotating lever (IMRC) and see if it rebounds to its original position. The lever must remain in its position, proving that the internal diaphragm is intact, and IMRC is good. Do the same test on the other IMRC.
If either of the two IMRC's rotating lever rebounds while your finger is plugging the port, the IMRC is bad.
At the same time, movement of the lever should be smooth with no binding. Process of elimination diagnostics need to be performed if the levers are sticky or binding. Figure out if the binding is occurring in the actual IMRC valve or inside the intake plenum by disconnecting the rotating lever from the rod. Be careful of the little plastic clips. They break easily and you'll need to be creative with ways to substiture for them if you can't find them at your local hardware supply.
Remember that by receiving the P1518 code, the PCM is only saying that the IMRC acuator itself is stuck open; the PCM has little way of knowing whether the butterfly valves inside the intake plenum are actually moving or not.
Finally, with the engine running at idle, rev the engine smoothly from idle to a little under 4,000 rpm and down again. You should see the acuators move in relation to engine RPM. This happens regardless of engine load nor vehicle speed. Doing this test in the parking lot proves IMRC functionality. If they're not moving, then you likely have a faulty IMRC which you can test as I described above (plug the vent hole with your finger after rotating the lever).
The PCM controls the movement of the IMRC's via a vacuum solenoid. Depending on engine RPM, the PCM opens and closes the solenoid to allow vacuum reaching the IMRC's. Thus, the solenoid is an active part of the system, and the IMRC's are passive. The IMRC's simply give feedback to the butterfly valves' relative position, similar to how a throttle position sensor tells the PCM - well, throttle position.
The solenoid (in my experience) rarely fails. The IMRC's themselves are more prone to failure.
Sep 9, 2009 at 2:29 PM
