1999 Ford Windstar battery charger light
MAPADOH
Electrical problem
1999 Ford Windstar 6 cyl Two Wheel Drive Automatic
after changing the alternater and charging the battery the battery light on the dash stays on. The system is checked with a multi meter. The altenater and battery both check ok after 24 hrs. Why is battery light on dash still on?
Jul 19, 2010 at 9:46 AM
Check fuses D and T in the engine compartment fuse box and also fuse no.14 in I/P fuse panel if all okay test the wiring and also for loose connections
Jul 19, 2010 at 10:17 AM
