it drive ok when you stare it cold once it hot it stare to mission
Mar 21, 2008 at 6:17 PM
MASTER TECH DAN
✓Experienced Mechanic
the plugs wires are bad and /or the coil pack
Mar 25, 2008 at 12:51 PM
OTIS HARRIS
MEMBER
on the 1999 ford windstar i chand the plugs wires and the plugs and coil pack and the02 and the egr but when i pull vac. off the egr when it was hot it ran fine no miss when i put the vac. back on it stare to miss again
