1999 Ford Windstar
HEAVYCHEVYMAN1987
Engine Mechanical problem
1999 Ford Windstar Front Wheel Drive Automatic
i try to turn on the car sometimes it cranks but recently i havent been ale to get it started, usaully i put gas in it and it will crank but that hasent been working lately. i am trying to figure out what can be the problem.
Jun 29, 2010 at 6:27 AM
  • 75,988 POSTS
Lets do below for a start to determine if its fuel or spark related issue and get back with some results
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jun 29, 2010 at 11:22 AM
