1999 Ford Windstar
GORDB
Engine Performance problem
1999 Ford Windstar 6 cyl Front Wheel Drive Automatic
engine sometimes does not want to idle when started (hot or cold).If you use the pedal it will continue running and after afew minutes its fine
Mar 16, 2009 at 7:12 AM
BILLYMAC
  • 2,204 POSTS
hi sounds like a idle air control motor. iac disconnect the neg cable for a min and then start eng run at 2000 rpms for 60 seconds this may reset the iac motor if not you have to replace it..billymac
Mar 16, 2009 at 7:20 AM
