1998 Ford Windstar wont start
130,000 MILES • 6 CYL • FWD • AUTOMATIC
MAGOO87
ok when it gets started i have no power in drive but if i put the car in low 1 i can move it but if i give it gas it bogs out it will start sometimes but not regularly . i changed the fuel filter and fuel pump but still no help anything you could think that it might be .its like it dont get fuel
Sep 13, 2009 at 9:03 AM
  • 75,988 POSTS
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Sep 13, 2009 at 9:08 AM
