1998 Ford Windstar Water oil leaking from my van
16,300 MILES • 6 CYL • 2WD • AUTOMATIC
MARTYO
My van is leaking this oily water from the right front of the engine. There's hot smell when I turn the engine off but the temp gauge isn't registering hot. I put coolant in the reservoir and the next day it was gone and there was blackish green slug in the bottom.
Sep 29, 2010 at 2:00 PM
  • 110,248 POSTS
It sounds like coolant. Have you checked the water pump for leaks and around the cylender head on the right front?
Oct 20, 2010 at 12:38 AM
