1998 Ford Windstar warning ding does not shut off
100,000 MILES • V8 • 2WD • AUTOMATIC
TGBARTO
the "ding" that tells if keys are left in ignition does not shut off or comes back on as we are driving
Mar 11, 2010 at 4:57 AM
KHLOW2008
  • 41,812 POSTS
Hi tgbarto,
Thank you for the donation.
Check the driver door switch. If it is not closing correctly or shorted, the warning chime would be turned on.
Mar 12, 2010 at 6:00 AM
TOWERMASTER86
Try spraying some silicone lubricant in your door latch. I had the same problem. Did that and the problem went away.
Mar 22, 2010 at 4:01 PM
