1998 Ford Windstar turn signals
75,000 MILES • 6 CYL • FWD • AUTOMATIC
FWALLACE
Turn signals will only work if the sterring column is all the way up (past last setting).. 4 way flashers work fine as do all other lights.
Thanks for your help
Nov 9, 2009 at 7:38 AM
BLUELIGHTNIN6
  • 16,542 POSTS
suspect damaged / loose connections at signal switch. need to remove the column shrouds and inspect the wiring and connections at the signal switch.
Nov 9, 2009 at 7:45 AM
