i own 1998 ford winstar the transmission was acting up it would rev up while driving the overdrive kept kicking in it would stall then kick into gear i had the filter replaced and the fluid then the fluid started leaking out slowly the pan was checked it was secured the first time now the car will not move when you switch it into gear i put it in rev nothing drive nothing i did this numerous times it will start up but thats it and all the fluid has leaked out
Aug 6, 2009 at 6:23 PM
