1998 Ford Windstar SURGING
189,000 MILES • 6 CYL • FWD • AUTOMATIC
TACOJOE362
CAN U TELL ME WHY SOMETIMES IT FEELS LIKE CHUGGING---SURGING AND HOW DO U FIX IT
Feb 14, 2010 at 12:15 PM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor
Catalytic converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Cap and rotor
Note:If it doesn't apply disregard.
Feb 14, 2010 at 12:19 PM
