1998 Ford Windstar Power window on driver's side only won't
GEA33
1998 Ford Windstar
I hava a 1998 Ford Windstar. One day the I hit auto down for the driver's window. It went down smoothly. Minutes later I clicked the up button and nothing happened. It has been stuck down ever since. The button clicks fine and there is no sound when the button is pushed. The other windiows work fine from that same driver's console. Is it a fuse, the motor, or the regulator that needs replacing?
Jul 16, 2008 at 3:37 AM
  • 75,988 POSTS
Jumper the motor on the up position and see what happens this will determine if its the motor, possible regulator-tracking/binding
Jul 16, 2008 at 1:42 PM
GEA33
[quote:c4d2ecc424="rasmataz"]Jumper the motor on the up position and see what happens this will determine if its the motor, possible regulator-tracking/binding[/quote:c4d2ecc424]
Jumper the motor? What does that mean?
Jul 16, 2008 at 3:58 PM
  • 75,988 POSTS
Apply direct battery voltage to the motor it will either go down or up to find its position up and down then go from there-
Jul 17, 2008 at 6:20 AM
