1998 Ford Windstar Oil pump
JANETNEESE
Engine Mechanical problem
1998 Ford Windstar 6 cyl Front Wheel Drive Automatic
Can you tell me where the oil pump is located?
Oct 22, 2008 at 12:10 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:358e5d8e46="janetneese"]Engine Mechanical problem
Can you tell me where the oil pump is located?[/quote:358e5d8e46]
The oil pump is bolted to the bottom of the engine block inside the oil pan.
Oct 22, 2008 at 12:28 PM
JANETNEESE
Thank you. I was hoping it wasn't there. But thank you so much for the quick answer.
Oct 22, 2008 at 12:43 PM
