I've been having a problem with my heat. It was blowing warm\cold recently and our mechanic replaced the thermostat. Seemed to fix the problem. Had heat for about a month or so. The last few weeks it has been blowing warm\cold again. We recently went to a relatives house about 45 minutes away. On the way home the heat was blowing cool again but this time the engine temperature was up at hot. We slowed down a bit and fiddled with the heater buttons ect. and eventually the temperature came right back down again only to go back up to hot. Someone suggested we check the coolant level. It was full but had a bit of a rusty or dark look to it. We put in a phone call to our mechanic who (without being able to actually check the car) said it sounds like a blown head gasket. Just wondering if anyone has any thoughts on this. If it is a head gasket is that expensive? Is it worth it on a car as old as mine?
Thank you for your help.
Maureen
Maureen
Dec 27, 2007 at 5:40 PM
