1998 Ford Windstar how to change plugs
133,000 MILES • 6 CYL • FWD • AUTOMATIC
SANDSTORM
hello, i just bought this van from my parents.they bought the van new. the problem is that this van still has the original 3 plugs and wires on the back side of the moter due to the fact that they are so hard to get to. my father likes to fix things himself, but this one whipped him!!!!!, like my father, i like to fix things myself also. is there an easy way to do this task? also i have another question about the air conditioning,when i turn the heat or air on the air may not come out the vent that i have selected, it is constantly changing from vent, floor, and defrost, i know that the vents work off of vaccume. is my problem in the controll switch? thank you !!
Nov 2, 2008 at 11:06 PM
2CARPRO JACK
  • 11,533 POSTS
I usually just remove the air intake boot and go around through that way to get to the rear plugs, there is no easy way. It does sound like the selector may be the problem, a loss of vacuum would make the air blow out of the defrost vents, not switch from vent to vent
Nov 2, 2008 at 11:39 PM
