1998 Ford Windstar horn don't work
14,200 MILES • 6 CYL • FWD • AUTOMATIC
VARMA
in the windstar my horn dont work from the steering wheel but when you use a power probe and power it up from thr connector under the dash it works theres no bad fuses or any thing.
________________________________________________________________________________________________________________________________________________________________________
i have tried adjusting the horn pads but still nothing when you use the power probe from the wires on the tabs it works not when its pluged in
Apr 12, 2010 at 5:19 AM
TOOOMANYTOYS
  • 513 POSTS
I would remove the horn pad and check the contacts. see if you can jump them there. It may just need a slight aedjustment of the horn tab.
Apr 12, 2010 at 5:25 AM
