1998 Ford Windstar heater problem
260,000 MILES • 6 CYL • FWD • AUTOMATIC
ALMARLBORO
when i turn on the heater ,the fan of raditor start
and that make the temp for the engine go down to zero and the air for the heater start come cold & cold
please if you can tell me how i can fix this problem special we are now in winter & i need to use the heater.
Dec 14, 2008 at 10:48 AM
SCHRIMPIEMAN
  • 166 POSTS
When using the heater, try using the "Vent" option on the selector dial, with the temperature dial set to red (warm/hot) setting. Vent should be just in-between the "A/C" selection and "Off". Using the selector switch on defrost setting or anything other than "vent" causes the A/C to kick in, alas causing the radiator fan to turn on.
As for your engine temp to go down, I suspect you may have a stuck open thermostat. A properly operating thermostat would prevent the engine from over-cooling regardless of the radiator fan being on or not.
It should go without saying that you need to make sure the heater has its radiator hoses attached, and the hoses (generally 3/4 inch ID) must not have any kinks preventing water flow. The cabin heater works by circulating the engine coolant through it. No hot water = no cabin heat.
Good luck.
Dec 20, 2016 at 1:12 PM
