1998 Ford Windstar heater blower
WALTERF
Heater problem
1998 Ford Windstar 6 cyl Front Wheel Drive Automatic 160k miles
GOOD DAY! My vans heater blower stays on even with the key out of the ignition. What can I do to fix it?
May 17, 2010 at 12:23 AM
  • 110,248 POSTS
The blower motor should only get power when the key is on. If you are getting it all the time, then the ignition switch must be bad. Have that checked and let me know what you find.
May 18, 2010 at 4:34 AM
WALTERF
I replaced one of the relay switches under the dash and so far the problem is solved. My neighbor thought it may be the ignition switch also, however, no other power item was running when the blower was. Thank you very much for replying to my question!! have a good rest of the week.
Walter
May 19, 2010 at 1:01 PM
  • 110,248 POSTS
I'm glad you got it fixed. Let us know if you have questions in the future, and thanks for using 2carpros.com.
PS: You have a good week too. Tomorrow is Friday eve!!! Just living for the weekends.
May 19, 2010 at 3:49 PM
