Heater not working?
135,000 MILES • 6 CYL • 2WD • AUTOMATIC
STEVE 123
Hi I have no heat at all up front but have heat in the rear was just working before?
Dec 10, 2008 at 11:49 PM
This is more than likely a blend door issue as you have separate systems in the van.
Here are a couple guides that will help with figuring this out:
https://youtu.be/SNRb6pSwYuU
https://youtu.be/Eqf-H3COtSo
Below you will find the process from the manual that will help with replacing this.
Please run through this info and let us know if you have other questions.
Thanks
Aug 1, 2021 at 11:50 AM
