1998 Ford Windstar Engine Starts, Can change the gears, but
89,000 MILES • 6 CYL • FWD • AUTOMATIC
VGANDHI
I was driving and suddenly the car stalled, The engine turns on, and I am able to change the gears without difficulty, but the van would not move, what can be the problem, I showed it to someone and they said you may need new transmission, while one of my friend thinks the 1998 ford had a trnamission sensor and it might have shut off, can you please help by guiding what can be the proble mand what to do?
Jul 23, 2010 at 11:27 AM
MERLIN2021
  • 17,250 POSTS
First step is to check the transmission fluid, on level ground in park with a hot engine. Then read the codes with a scan tool, post all codes found. If it is a shift solenoid or module, there will be a code. Hand held scantools are cheap and a good tool to have since by Federal law, all cars since 1996 must have OBD II connector!
Jul 24, 2010 at 2:31 AM
