1998 Ford Windstar Dome Light Delay
106,000 MILES • 6 CYL • FWD • AUTOMATIC
EBEHAWK
Dome Light/courtesy lights come on when turning off ignition ( All Doors ar closed/latched). Dome light stays on after locking all doors/set alarm with remote (up to 20 min). Cannot turn off dome and courtesy lights. Dome Lights will go off a few minutes while driving.
Other Symptoms:
Door Ajar dash indicator will remain on while driving.
Auto Lock when placing in gear may or may not work ..but delayed
Feb 19, 2010 at 3:59 AM
MERLIN2021
  • 17,250 POSTS
Try this cure, buy a can of brakekleen and a can of spray white lithium grease, spray the latch area, thats the claw in the door where it closes, spray liberally with brakleen, open and close the door 5-6 times, repeat, then spray with the white lube, open and close the door 5-6 times. Reapeat on all doors...
Feb 19, 2010 at 5:17 AM
