Believe me, it may seem a little intimidating at first, but if you can get Cyl #1 at 26 degrees after TDC as and make the mark on the crank pulley as described in Step 2, you will be successful.
The article does not mention, however, that the 26 degrees A-TDC needs to be on the COMPRESSION stroke, not the exhaust stroke. If you get your crank on the exhaust stroke, you'll get the code again. Be sure you are on the compression stroke.
I've done this on several Ford V-6 engines and the procedure is flawless!!
However, similarily, I've encountered the CMP sensor completely destroyed as well, causing the fault code. This sometimes requires removal of the CMP shaft assembly if the little rotating tab is damaged (where the plasitc CMP sensor actually sits on).
You'll need to move a few items from the immediate area (power steering hoses, serp belt, etc) to gain access to the CMP sensor, but with a little patience, the process is straight-forward.
Dec 18, 2008 at 3:13 PM
