1998 Ford Windstar Brake Lights Won't work!
JTHOMPSON14628
Electrical problem
1998 Ford Windstar 6 cyl Front Wheel Drive Automatic
I have a 98' Ford Windstar, the brake lights will not come on. I have replaced the switch under the brake pedal, and the fuses, and the bulbs. What else should I do?
Apr 24, 2008 at 10:22 AM
  • 31,937 POSTS
Hi there,
Check the power flow through the switch is ok. Check for voltage at the globe holders, if ok check earths, if no voltage start back tracking the loom.
Mark (mhpautos)
Apr 24, 2008 at 8:57 PM
