1998 Ford Windstar 98 Ford Windstar
LARRY915
  • 1998 FORD WINDSTAR
  • 6 CYL
  • 90,000 MILES
MY 98 FORD WINDSTAR WILL NOT START. IT TURNS OVER BUT NOTHING. I HAVE CHANGED THE FEUL PUMP AND CHECKED FOR SPARK. IT DOES HAVE SPARK. WHAT ELSE CAN IT BE?
Monday, May 24th, 2010 AT 4:47 PM
  • 109,885 POSTS
Are you getting good fuel pressure to the rail? Also, have you checked to make sure the injectors are getting power?
Will it start for a few seconds with starting fluid?
Thursday, June 24th, 2010 AT 11:51 PM
LARRY915
THERE IS LITTLE FUEL PRESSURE TO THE RAIL. I CHANGED THE PUMP AND THE FILTER. IT WILL STAR FOR A FEW SECONDS IF I SPRAY FUEL TO THE THROTTLE BODY.
Friday, June 25th, 2010 AT 11:10 AM
  • 109,885 POSTS
If you aren't getting enough fuel pressure, the injectors won't work. Have you checked for kinked or damaged fuel lines? If the pump is new and is getting power, something is stoping the pressure from building at the rail.
Recheck the lines and let me know what you find.
Saturday, June 26th, 2010 AT 1:35 AM
LARRY915
I WENT AHEAD AND REPLACED THE PUMP AGAIN. THOUGHT IT MIGHT OF BEEN A FAULTY FEUL PUMP. CHECKED THE LINES NO KINKS. NOW I'M NOT GETTING ANY PRESSURE WHAT SO EVER TO THE RAIL. YOU CAN HEAR THE PUMP TURN ON WITH THE KEY. CAN IT BE THE FEUL PRESSURE REGULAOTR OR RELAY? I ALREADY CHANGED THE FILTER ALSO. IT JUST WOULDN'T START FROM ONE DAY TO THE NEXT.
Monday, June 28th, 2010 AT 10:59 AM
  • 109,885 POSTS
It could be a bad regulator. Here is a how to for checking fuel pump pressure and the regulator. Check it and let me know what you find.
Tuesday, June 29th, 2010 AT 10:22 AM
  • 109,885 POSTS
Sorry, I hit reply before adding the directions. Here they are:
http://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Tuesday, June 29th, 2010 AT 10:26 AM
LARRY915
THE REGULATOR IS ON THE TANK WITH THE PUMP? OR BY THE RAIL? LIKE I SAID NO PRESSURE COMING OUT WHAT SO EVER NOW.
Tuesday, June 29th, 2010 AT 10:29 AM
  • 109,885 POSTS
It should be on the fuel rail.
Tuesday, June 29th, 2010 AT 12:44 PM
