1997 Ford Windstar won't start
1997 FORD WINDSTAR
20,000 MILES • 6 CYL • FWD • AUTOMATIC
RRUSHING
For awhile the engine would lope or miss at idle, then the other day it shut down and wouldn't start. Is it the fuel pump.
Jul 1, 2010 at 2:01 AM
Hi rrushing, Welcome to 2carpros and TY for the donation.
What you need to do is determine if its a fuel or spark problem that's preventing it from starting-Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jul 1, 2010 at 10:22 AM
