1997 Ford Windstar Oil Pan Gasket
ZAKKER500
Engine Mechanical problem
1997 Ford Windstar 6 cyl Front Wheel Drive Automatic 182K miles
I recently noticed that my oil pan may be rusting through. I purchased a new one from Ford and they sent me a tube of silicone to use as a gasket. I tried to get a gasket (preferably cork) from Auto Zone and NAPA. Neither place had access to a gasket, just the tube of silicone. Is that gasket available from anyone, or will I be safe enough using the silicone?
Also, it appears that I just have to remove the starter in order to remove the oil pan, or do you think the exhaust pipe may have to be removed too?
The engine is a 3.8L.
Zak
Mar 21, 2008 at 1:57 AM
2CARPRO JACK
  • 11,533 POSTS
Yes, the exhaust will need to be removed. I would also use a good silicone, I prefer GMS (General Motors Sealant) found at Chevy dealer. Get all surfaces real clean and oil free, this stuff is like glue, works great,let dry as long as possible before starting or filling back up with oil
Mar 21, 2008 at 4:21 AM
ZAKKER500
Jack,
Thanks for your help on this subject. What I still don't know is, are there any cork gaskets available for the job and wouldn't that be better than silicone?
Zak
[quote:71fb3d4c59="2CarPro Jack"]Yes, the exhaust will need to be removed. I would also use a good silicone, I prefer GMS (General Motors Sealant) found at Chevy dealer. Get all surfaces real clean and oil free, this stuff is like glue, works great,let dry as long as possible before starting or filling back up with oil[/quote:71fb3d4c59]
Mar 24, 2008 at 12:24 PM
2CARPRO JACK
  • 11,533 POSTS
If the dealer and two parts stores dont list one, then there probably isnt one. Be sure to get it real clean (carb or brake cleaner) or the silicone wont stick
Mar 25, 2008 at 12:33 AM
ZAKKER500
Thanks again Jack. I wanted to leave a positive review and points but this rediculous site just won't let me do it.
Zak
Mar 27, 2008 at 10:46 AM
2CARPRO JACK
  • 11,533 POSTS
Thanks, we are working on the site, needs some fine tuning
Mar 28, 2008 at 12:31 AM
