1997 Ford Windstar oil loss
1997 FORD WINDSTAR
MOMOF4GIRLS
Engine Mechanical problem
1997 Ford Windstar 6 cyl Two Wheel Drive Automatic
I was driving my 1997 windstar this morning when it suddenly started to make a popping sound and then started to smoke, and all the oil poured out of the car!
May 30, 2008 at 4:02 AM
  • 31,937 POSTS
Hi there,
You may have suffered a major engine failure. I would start with checking that the oil filter and the sump plug are still installed and tight. You will have to wash the engine down re fill with oil and see if it will start, then run and see where the lead is coming from. If the engine starts and makes any loud knocking noises, shut down and contact you mechanic.
mark (mhpautos)
May 30, 2008 at 5:56 PM
