1997 Ford Windstar Blower speed control
133,000 MILES • 6 CYL • FWD • AUTOMATIC
FATTONY
On my windstar van the heater and A/C only physically blow air when the blower speed switch is set to high. Alll the other positions dont do anything. I already tried a switch from the ford dealer which produced the same results. Is it the blower itself ? I am a backyard mechanic but, I cant follow the wiring harness even after taking half the dash apart. The harness kind of disappears . What could it be ? Is there a relay which controls this ?
Jan 25, 2009 at 2:34 AM
JDL
  • 16,098 POSTS
Hello, I don't have a wiring diagram for your blower. Usually the high speed is wired differently form the lower speeds. The lower speeds use a resistor circuit. I'd check the circuits at the blower resistor.
Jan 25, 2009 at 2:54 AM
FATTONY
Where is the resistor circuit located? What would you do and how?
Jan 25, 2009 at 3:01 AM
FATTONY
When I find the resistor circuit , how many ohms should it read? Thanks.
Jan 25, 2009 at 3:03 AM
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_blower_resistor_1.jpg
That's a picture out of the parts book, for the resistor. I don't have a location. You might follow the blower motor connector. As far as testing, Turn everything on, turn the blower speed to a lower speed, check for voltage going into the resistor and out. I don't have a wiring diagram on this, I have it for a 99 not sure if the wiring colors are the same?
Jan 25, 2009 at 3:52 AM
FATTONY
Thank you . I will look into finding where this resistor is. I might start at my parts store or ford parts counter on saturday. Once I find out where it is , I can check it and replace it if thats my problem . Thank you so much for your help.
Jan 25, 2009 at 3:58 AM
