1996 Ford Windstar what is wrong with my front end
1996 FORD WINDSTAR
132,564 MILES • 6 CYL • FWD • AUTOMATIC
AZFRHONDA
After replacing my front passenger side callipers,rotor,and brake pads my van is popping,grinding and sounds like my tire is going to fall off when driven whether in drive or reverse I think it my cv joint or wheel bearing am i on the right track
Jun 1, 2009 at 10:36 AM
JIS001
  • 3,412 POSTS
Check your control arm bushings. If this is the 3.8L engine the oil filter is on the right side and every time the oil gets changed oil from the filter starts to get on the rubber bushings causing to split.
Jun 3, 2009 at 8:14 PM
