1996 Ford Windstar Van won't start.
M BLAZE
  • 1996 FORD WINDSTAR
I was on the highway (traveling 70 mph) and the van just stopped running. It cranks, but won't turn over. I was wondering if the failure could be due to bad o2 sensors or should I automatically be concerned about a new fuel pump?
Wednesday, June 2nd, 2010 AT 11:12 AM
  • 110,182 POSTS
An O2 sensor won't kill the engine. It will cause a performance issue, but not prevent it from starting.
There are two things you have to check for, spark to the engine and fuel pressure. Here are the how to's for checking. One will be the cause. Let me know so I can help you trouble shoot the problem.
https://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
Wednesday, March 24th, 2021 AT 6:54 PM
