1996 Ford Windstar ruff running
WILLIAMKARL
1996 Ford Windstar 6 cyl 220000 miles
when starting the van, it seems to run ok untell it gets warm (normal operating temp) then runs ruff and a miss ,no power run, no engine light. new mass air flow senser, scan revels low flow in egr, open rails, miss in number 3, o2 bad... i have removed the intake manifold and clean the rails with carb cleaner.no difference
Jul 10, 2008 at 4:39 PM
OBXAUTOMEDIC
  • 3,719 POSTS
[quote:397d28447a="williamkarl"]1996 Ford Windstar 6 cyl 220000 miles
when starting the van, it seems to run ok untell it gets warm (normal operating temp) then runs ruff and a miss ,no power run, no engine light. new mass air flow senser, scan revels low flow in egr, open rails, miss in number 3, o2 bad... i have removed the intake manifold and clean the rails with carb cleaner.no difference[/quote:397d28447a]
With a miss in the #3 cylinder and not replacing at least the Spark Plugs there won't be any improvement. Change the Plugs and see what happens. The miss can be caused by the plug, plug wire, bad tower on coil pack, bad injector, or injector harness.
Jul 10, 2008 at 11:59 PM
