Thanks for the response. I did the initial bleed on jackstands at idle, but only turrning the wheel lock to lock a few times, and only the one time. The growling has not stopped, nor lessened any. I replaced the first pump and bled while the vehicle was on the ground. That pump was quiet initially, but started growling after a few months. I used a pulley puller designed for these pumps to remove the pulley, so I believe there was damage to the pump from that. Also, on this pump, I used a puller that I purchased to install the pulley as well, went on like butter. I am wondering if there is a way to bleed, or drain out the rack, thinking that it may be the problem. Thanks again, and if you have anything else helpful, I'm all ears.
[quote:075c3dbcb0="Schrimpieman"]Letting Ford pwr. steering pumps growl even for a short period of time ruins them fast, so if you've had the pump make the noise for more than a few minutes, you may need another pump. They are very sensitive pumps; air in the system causes them to go faulty easily.
First the good-case scenario, then I'll provide a bad-case scenario...
Good Case: Make sure the resovoir is full... let the car rest overnight. Small air bubbles in the system can make the noise, even if the liquid looks "full". What happens when there's too much air in the system is that the pwr steering fluid gets saturated with tiny air bubbles (kind of like when you open a warm 2-liter soda bottle)...l all that air gets suspended in the liquid and makes hard work on the pump. Let the car rest overnight. Jack up the front end so there is no stress on the front tires. Without engine running, turn steering wheel lock-to-lock slowly a few times. Keep resovoir full, but beware of turning the wheel causes pressure, and the resovoir may spray out fluid......so turn the wheel slowly. Take about 20 seconds from left-right-left lock-to-lock. Start the engine and immediately turn the wheel extreme left to extreme right (lock-to-lock) without slamming the wheel when it reaches it's limit. In other words, when the steering wheel reaches it's turning limit, turn the opposite direction immediately. Don't turn the wheel too fast. If it takes about 10 seconds from lock-to-lock, that's about the correct turning speed. Do this about 20 times, or until you hear the pump getting more quiet. Shut engine off...keep vehicle jacked up. Start engine again after 30 minutes or so and repeat lock-to-lock. The secret with hydraulics is patience and no stress on components while bleeding them.
If this doesn't quiet down the pump noise after 4 tries or so, you'll need to replace the pump and try again.
Thus, the bad-case scenario: Replace pump again and bleed system with front end jacked up as explained.
In any case, work with an assistant to ensure that the resovoir always remains full. Have one person start the engine from the driver's seat, and have another person with a small bottle of pwr steering fluid hovering over the open resovoir to immediately replenish any fluid that the pump sucks in to fill up the system. The secret (again) is patience, having the least amount of air bubbles being circulated in the system, and getting the front end jacked up to eliminate stress on the front wheels while they are being turned lock-to-lock.
Oh, and do this with engine idle. The faster the engine is turning, the smaller the little bubbles will be chopped up, and the longer it will take to bleed. Big bubbles are easier to expel than small ones. Keep the engine at idle. Don't rev engine up in efforts to get fluid flowing faster thru system. This is counter-productive.[/quote:075c3dbcb0]
Mar 5, 2009 at 1:14 AM
