1996 Ford Windstar overheating
213,000 MILES • 6 CYL • FWD • AUTOMATIC
BEE39520
i had to change the head gaskets, then i changed the water pump, then the thermostat, radiator cap and radiator. put coolant in it... now if you take off fast or you are in traffic it runs hot, but when you get up to 50mph it cools down...i changed all this because it was running hot and i was getting oil in the overflow jug, along with the water. the radiator is now pumping the water in the overflow. please help
Jul 15, 2008 at 5:29 PM
  • 31,937 POSTS
Hi there,
I would be re checking for a head problem, Was the head crack tested? surfaced? all the mating surfaces spotless? have the coolant checked for exhaust gasses, your mechanic can do this. Start here.
Mark (mhpautos)
Jul 15, 2008 at 5:57 PM
