1996 Ford Windstar not starting
DIXIEDELIGHT25
Electrical problem
1996 Ford Windstar 6 cyl Two Wheel Drive Automatic 123thousand
starts fine when is cold once gets to normal running temperature and cut it off and go to start it back up will shake and sputter and sometimes cuts off does for about 5 minutes then runs fine again any thoughts to what it might be?
Jul 16, 2008 at 9:10 AM
  • 75,988 POSTS
For a start check and monitor the fuel pressure, also the idle speed control motor/valve
Jul 16, 2008 at 10:21 AM
